I did not say I never use the codebook, just when there is questions. Do you read the owners manual for your car every time you drive it? And yes this this forum is a great place to learn things, it keeps my mind active in areas that I may not run into all that often but I still have some knowledge of those installations and will be very useful when I do run into similar installations. When inspecting do you walk around the inspection site with open code book? Likely not, you look for things you don't expect to see, and if you don't know exactly which section is violated or if it is a violation you then look in the code and find the section that applies. If inspecting some type of installation you are not all that familiar with the chance of the code book coming out increases, same with me when installing.
I was just chiding you a bit.
In reality I own code books because I like books. I have over a hundred electrical books and several hundred automotive books (former ASE tech specializing in electrical systems)
Also, in reality, there is no comparison to an owner's manual and the NEC. Does your owner's manual get updated every three years? Does your owner's manual get adopted by a jurisdiction as law?
I am not an inspector, so when someone does call me to look at a job for code compliance, yes, I do have a code book with me. (People don't call me for easy stuff for some reason...)
When I do a job that is at all sizable, there
will be a code book on the bench or table when the inspector gets there. Many inspectors in smaller jurisdictions don't carry books with them and I refuse to take that as an excuse for them not being able back up their mandates with the book.
I am used to the 'I don't need a book' attitude. It transcends our trade and is prevalent in amateur radio as well. 90 percent or more licensed operators don't own a copy of CFR 47 Part 97, a book the size of a pamphlet that covers federal FCC laws that must follow international (ITU) rules. That book only costs about 6 bucks.
What amazes me is how many people will bullheadedly argue rules when they don't even own a rule book.
And I came from an industrial background where all the wires are the same color. I am used to it, but BY FAR prefer to work with conductors marked for their purpose in some manner. It's one less thing for me to have to concern myself with.
The automotive industry has no rules for electrical systems. There are some patterns, like black for ground, red is on w/key and orange is on all the time. In the late 80's Ford decided to use a red wire to ground the radios in their Ranger pick up trucks. Yes, it resulted in significant damage when radios were being removed or upgraded. Every service call I went on to repair those Rangers was due to damage done by experienced mechanics connecting the wires wrong due to Ford's better idea of using red for a ground wire.
Color coding wires based upon use is just good design work. It has nothing to do with 'idiot proofing'.
