burrs in conduit
dlhoule
Michigan
I have found the German language much easier than the Japanese. At least the german prints are consistent. The japanese seem to have different systems depending on the company.:mad:
sleeving the pipe
sleeving the pipe
one other reply mentioned a plumbing contractor to ream the pipe...but most large companies that deal with having to retrofit underground piping have a sleeving system to reline pipes that must be reused and cannot be excavated for repairs or replacement. that may be an option if the conduit size and wire size allows the fill percentage to remain within specs, so if the camera inspection shows the problem , this might be a solution, also, if this is feeding a motor , there is some additional de-rating allowed for motor conductors to give you more room to work with.
