Ratfink
- Washington
- Engineer
Hi Everyone,
Im currently building a mobile Power Distribution Box, 220/110 VAC Single Phase. They are used for Stage Lighting, Music equipment. Looks similar to THIS.
Will use Mini Breakers, typical 110 VAC plug outlets and 220 VAC Dryer Plug Outlets. Essentially a mobile breaker box with outlets.
My Question is regarding connecting the incoming 4/0 Neutral and both Hot wires to seperate Bus Bars inside box.
Any thoughts or ideas related to Bus Bar Options with screw clamps would be welcomed and appreciated.
Thankyou all in advance.
- Does anyone make a 200 amp Bus Bar that is designed like Grounding Bars with the screw wire clamps. A larger version of THIS that can handle 200amps one for each Hot wire and the Neutral?
