IR Scan showed 3 times the heat on Compression.
What exactly is '3 times the heat'?
Exceptions....such as....
Screw to 69 or 70 F
Compression to 73 or 74
Actually, the most widely accepted spelling is "smuts", as in the plural of smut.That's "schmutz." L'chaim!
2 years ago?? The problem with tinkering and too much crammed in the head:wink:
both at ~67 F start (appx)
After coffee break 20- 25 min ~
Screw to 69 or 70 F
Fluke IR Camera from PM Tools.
amps ??? I forget
We had left it with Pop off jammed open.
More detailed and i would have to get paid to do it again
And I would have to find that darn compressor too:smile:
Maybe less area, but definitely greater pressure. I try to drive the screws all the way. The deeper the dimple, the better the pull-out resistance and better conductivity. It's certainly not going to impinge on a properly-filled conduit's area.That deflection, or flattening of the conduit, can make for less contact area.
Smut was derived from shmutz (Yiddish) and/or schmutz (German). Means the same thing.Actually, the most widely accepted spelling is "smuts", as in the plural of smut.
Compare each rise from the original of 67 deg. SS: + 2-3; comp: + 6-7. That about 3x.I guess I wouldn't call a 4?F difference '3 times the heat'.
Now for a hi-jack? =)
Snugger than what?Has any one found a particular set screw connector and or coupling with a snugger fit on the EMT? Off the top of my head I prefer OZG steel connectors, and detest most any cast ones.
:smile:Doug S(ch).
simple question,are compression coupling/connectors superior to set screw on an indoor installation.If so how?
Perhaps its origin depends on the reference...Smut was derived from shmutz (Yiddish) and/or schmutz (German). Means the same thing.
Merriam-Webster Collegiate? Dictionary
1smut
Pronunciation: 'smət
Function: verb
Inflected Form: smut?ted ; smut?ting
Etymology: probably alteration of earlier smot to stain, from Middle English smotten; akin to Middle High German smutzen to stain
Date: 1587
transitive verb
1 : to stain or taint with smut
2 : to affect (a crop or plant) with smut
intransitive verb : to become affected by smut
x
2smut
Function: noun
Date: 1664
1 : matter that soils or blackens specifically : a particle of soot
2 : any of various destructive diseases especially of cereal grasses caused by parasitic basidiomycetous fungi (order Ustilaginales) and marked by transformation of plant parts into dark masses of spores also : a fungus causing a smut
3 : obscene language or matter
That's funny; you don't look Jewish!Oy, don't be a kvetch boychik.:grin:
It also helps to know that Yiddish is a conglomerate language, derived from Polish, German, etc., as well as Hebrew.Perhaps its origin depends on the reference...
I just don't see the relevance. There must be an implied reference that you're just not letting on about.... :-?It also helps to know that Yiddish is a conglomerate language, derived from Polish, German, etc., as well as Hebrew.
