Cleveland Apprentice
- Cleveland, Oh
I have a manual transfer switched that doesn't switch the neutrals between utility and gen power (non-SDS). I have a generator that does not have a "floating neutral." I understand that I must have a floating neutral to work with this type of transfer switch or I would have parallel current traveling on the EGC back to the gen. If I converted this to a floating neutral, wouldn't this make the generator a dangerous set up if I decided to use this as a stand alone generator for other purposes? I am curious of what options there are. Thank you.
