So the pump(which is the voltage source) pushes the water(electrons) through the pipe.
so all the electrons which are being pushed come back to source and this process is repeated 60 times
in one second..am i correct here?
To answer this question, I have to rescind my honoring of Charlie's request, as noted at that time... though I will try to avoid a technical discussion of drift velocity.
Several parameters of the closed-loop system will determine what water molecules (electrons) actually return to the pump (voltage source). Water molecules (electrons) fill the piping (wire) at all times. As molecules exit the pump, molecules enter the pump. The molecules exiting and entering are different molecules. The parameters?pressure, pipe size and length, restrictions (impedance), etc.? determine whether any molecules which exit the pump actually return to the pump during each cycle.
Jumping to the electrical side, in most cases other than extremely high current and small, short wires, the actual electrons (if you could manage to label each and every one) leaving the voltage source (pump) do not return to the voltage source within each cycle. This is analogous to water molecules leaving the pump at the end of a cycle must remain in the pipe to maintain its full-of-water status.
