kwired
Electron manager
- NE Nebraska
Not that I'm aware of. Non-residential requires test bypass type meter bases and rating is 200A. Above 200A is CT's. Not a lot of industrial loads up here, though. Bigger industrial get primary metering. Mostly ski resort type stuff such as hotels, restaurants, bars, etc. Been here 18 years and never hooked up anything less than 200A non-residential. Even sump pump, lighting, etc. get 200A. Probably due to our rate structure regarding 200A or less being the same fees. Probably not typical.
Type of thing I had in mind was services for signs, communications, lift stations, roadway lighting, just to name a few. Often those types of loads are very limited and can run on 30 or 60 amp supply.
