ner
- connecticut
I have been told that a two pole switch can serve as the disconnect for a MWBC to a shed. What about article 225.38 (C) 2005 NEC that says the neutral needs to be disconnected too. Do you install a terminal with pressure connectors in the box with the two pole switch or add another single pole switch or a three pole disconnect to satisfy this requirement? There is one 20 amp 120/208 volt MWBC in this situation.
