hockeyoligist2
- close to greenville sc
I have tried the drill doctor, not too good.
jdsmith asked why would I want to sharpen bits in the field? Sometimes I need to sharpen a bit in the field. I tap all holes. If I need a number 7 for a 1/4-20 I don't use a 13/64, I don't just grab something close to the size. I often have to move something over a little or remount things because someone used the wrong size and it stripped out the threads. I also know the speed and and feed rates, necessary coolant/lubricants, and the difference in types of metals. I was asking if anyone knew of a good portable drill sharpener. Not a looking for a lecture.....I used to be a tool and die man, I don't rig it. And I never ream a hole with a bit, I use the proper size.
I sharpen them at the shop by hand on a bench grinder, after I get back to the shop, split points also (yes it can be done if you know what you are doing and I do). They last many times longer than a new cheapo bit at the supply house. If a bit is getting dull, I don't force it and ruin the bit. I would rather touch it up until I can finish the job.
electricalperson said "your boss should provide you with drill bits." They will provide a few, but they don't meet my standards. I brought my own from home, my old tool and die stuff. My boss reams out a hole and puts a nut on the backside. The next time something needs to be removed you have to take everything apart to get to the nuts. I'll get scolded for this probably.... but he used to be a city of Greenville inspector!
I'm sorry if I sound like I am ranting............. well, I guess I am.........
I hope no one has been injured by these comments. I am just a little bit of an azz today!
