Carultch
- Massachusetts
As far as bare, I often see that specified for non-metallic conduit runs. The idea is with a bare EGC, you should be able to clear a ground fault within the non-metallic raceway quicker than if you had installed an insulated EGC. Other than the non-metallic raceways, I don't think I have installed an bare EGCs.
Interesting. Never thought about that.
Does a bare ground wire cause abrasion problems for the insulation of the remaining wires, resulting from the wire pull?
