I understand your concept on using couplings to comply with support spacing (even though it goes: connector 3', 5', 10', 10'... 3', connector), but it is not required to be that way...cadpoint said:It's the way I do it with a horizontal run. Full 10 foot sticks
If you cover the first 3' with a strap, and continue on I'll put a second strap on the end
of the first (same) conduit before a coupling, that is two feet from the end.
Then I'll go ten feet from the point of second strap which will be 8' down from the last
coupling which will be for the second conduit and strap the conduit.
Two things it looks good and it also employs a stap ready for the next conduit.
110.12
