- Illinois
- retired electrician
This faceless GFCI is listed as both a GFCI (KCXS) and as a "Motor Controllers, mechanically operated and solid state" (NMFT). The question is if this device can be used as a code required motor disconnect? I don't think so as you don't have physical control of the power contacts in the device. I see it as being the same as trying to use a control circuit as the lock-out....something that is not permitted. Looking for other comments.
