A project I am working on has a 400A MLO panel (208/120) and I need to add a second section. Is it ok to add feed thru lugs to feed a 225A MCB panel to be located right next to the 400A MLO?
There is about 12" of space at the bottom of the panel, which should suffice for the added lugs and the 4" min wire-bending space for the 1 set of #4/0s needed to feed the MCB of the new 225A panel.
I just want to make sure Im not overlooking anything that may violate code - thanks all.
