To advance the discussion, would you please tell me again the exact language in the NEC that says that an outlet can only occur on the boundary of the Premises Wiring System?
Sure. Again, it is in the Definition of Premises Wiring (System):
Premises Wiring (System). Interior and exterior wiring, including power, lighting, control, and signal circuit wiring together with all their associated hardware, fittings, and wiring devices, both permanently and temporarily installed. This includes (a) wiring from the service point or power source to the outlets or (b) wiring from and including the power source to the outlets where there is no service point.
Such wiring does not include wiring internal to appliances, luminaires, motors, controllers, motor control centers, and similar equipment.
Now, at first flush, one is inclined to still think (I believe this to be another distracting meme) that the Premises Wiring (System) must be continuous, that is not in segments, between power source or service point and the outlets, but I believe a 400.7(A)(11) listed assembly is just that, "a segment of Premises Wiring (System) ending in an Outlet.
Not only are there "segments" but there is apparatus installed
within the Premises Wiring (System) such as Controllers and Motor Control Centers, that are DEFINED as NOT part of the Premises Wiring (System). Controllers and MCCs create pools of NOT Premises Wiring (System)
within the midst of the Premises Wiring (System). That is interesting to me. There is an electrical circuit that comes out of the Source and goes all the way through the Load and then returns to the Source. . . an electrical circuit. But there are these legal boundaries along the circuit.
So, for the purpose of clarity, I strip the electrical circuit to a
simple example. A PoCo transformer secondary 120 Volt winding is the Source. The two wire service drop brings the beginning of the electrical circuit to the Service Point (a legal boundary between PoCo NESC and the NEC ruled Premises Wiring (System)). From the Service Point the electrical circuit goes to a Controller (the simple snap switch) which in turn is connected to a receptacle outlet where a cord and plug connected Appliance is connected.
Having set the stage of our thoughts, I now wrap in the next set of your questions and comments:
I can only find the "taken to supply" language in the definition of outlet. If that is the language you use, would you please give your definition of it? I do not see a definition of it that would includes the snap switch without removing the boundary condition.
The
simple example has, when the Appliance is running, only ONE current circulating, the current determined only by the electrical characteristics of the Appliance in relationship to the Source. The current supplied by the Source is the current taken by the Appliance. There is only one current in the complete electrical circuit.
There is no other Load. The conductors and contacts are all loss-less, as this is the boiled down simple example. Therefore, there are no other currents. (Remember that an Outlet is ONLY about CURRENT). The Controller, being a simple snap switch, receives outside mechanical (not electrical) energy from a human operator, to govern the behavior of the Appliance.
Now, because the simple snap switch is wired in as a Controller for the branch circuit downstream of the switch, to the Receptacle Outlet, and in turn the Appliance, the wiring internal to the controller is defined, by Premises Wiring (System) as being NOT INCLUDED which is the legal boundary from NEC to NOT NEC. . . The "NOT NEC" that I am paying attention to is what is defined as the internal wiring of a Controller. It is also, at once, a device that is a switch, but the added condition of being a Controller dominates, in my opinion.
So, the current passing through the internal wiring of the Controller is the current taken by the appliance, and there is that POINT on the WIRING SYSTEM where the current taken to supply the appliance goes into wiring that is NOT wiring system. This is identical to what happens at a Receptacle Outlet. I have arrived at seeing that the definition of outlet describes the condition at the point on the wiring system that is beside and in continuity with the internal Controller wiring that is defined as NOT wiring system. That is how I define an Outlet occurring in a simple snap switch used as a Controller.
