- Tennessee NEC:2017
- Semi-Retired Electrician
I know a separate structure needs a ground rod or GEC, but I have a slightly unusual situation. I need to set a sub panel on the outside of a house. Normally if it's on the same house/structure as the main, you would just use the EGC from there.
What I have is, the house has a new set of steps made of the decorator type blocks that I want to mount the sub panel to.
Since the steps are for the house and run right up to it, would that count as the same structure and no additional GEC/ground rod would be needed?
Here is a pic of the old steps which have been torn down. I didn't get a picture of the new steps because my batteries were dead in the camera. I did get a picture that shows what the blocks look like if you can make them out. I want to mount the panel on the right side of the new steps.
Another question, what would be the best way to mount the panel on these steps? As I said, the steps are made of what I suppose are landscape blocks that have a decorative front. Should I mount directly to them, or maybe some strut or some type of backer?
