Residential ranges, residential washers, residential dishwashers and residential kitchen refrigerators.
OK,
Here is the real world, you go to pull out the refrigerator from its spot. Of course you don't do this often, who does? But it happens from time to time. You can't unplug it first because the plug is behind it so you start wrestling this heavy appliance out and the next thing you know the cord gets yanked out of the wall leaving the ground pin in the outlet.
That is exactly the kind of reason GFCI requirements where recently added for vending machines.
I also repair the same issue on deli meat slicers all the time. They are heavy, they get moved each night for cleaning, the employees forget to unplug them and bam, another ground pin is ripped out.
So while I understand your point that say a small portable appliance gets plugged in and out much more often then heavy appliances heavy appliances are much more likely to damage the plug and / or cord.
I have not made the claim that they never end up without an EGC, my claim is that they are far less likely to when compared to portable appliances.
And I am still waiting to see the source of this knowledge.
Or are you just like NEMA?
