iwire said:
In this case they must have tried to be equivalent of at least a 3/0 CU or 250 AL.
As far as how you determine the ampacity I believe you can find that in the NEC.....I just can't remember where.
But I can tell you that 1/4" x 4" copper is usually good for a 1000 amps.
I believe one would be hard pressed to find busbar ampacity in the NEC, other than perhaps a couple places, at best, for specific situations and as I recall, an implied ampacity at that... but I can't remember exactly where the text is located.
Regardless, I believe you will find busbar ampacity is usually limited by factors other than the busbar's ability to carry substantial current. In and of itself, it will carry current until it melts to the point of opening the current path... same as wire. Nevertheless, busbar ampacity is given in terms of temperature rise. The mentioned size of 1/4" x 2" as a copper busbar is rated 710A @ 30?C Rise, 60Hz. Compare that to 1100A @ 65?C Rise!!! [Source:
copper.org]
Note the cited code spec's
either aluminum or copper busbar...
