four said:Does a 240 Gfci breaker need the neutral for the test function to work. Will it work without. Wired up a straight 240.v circuit no neutral and test button doesnt trip????. New breaker does same thing.
stickboy1375 said:The GFCI breaker needs the neutral, the load probably does not...
You mean a load neutral?four said:Does a 240 Gfci breaker need the neutral for the test function to work.
The first image is copywrited but you can view it here .four said:Does a 240 Gfci breaker need the neutral for the test function to work. Will it work without. Wired up a straight 240.v circuit no neutral and test button doesnt trip????. New breaker does same thing.
cadpoint said:Edit : welcome to the forum and whats your handicap ?
Don't worry, cadpoint is on-line.four said:I am having a tough time typing tonight
:grin:four said:but there is no to get out of way but there is no
four said:My handicap is working for ten hours is 95 degree temperature 90 humidity. It sucks the life right out of you
four said:There is no load neutral it is a 240v application. I Landed pigtail on neutral bus but there is no to get out of way but there is no neutral.
RUWired said:In the images Cadpoint linked, the piggy tail from the breaker goes to the load side terminal neutral on the breaker, not on the neutral bar.
Rick
