LarryFine
- Henrico County, VA
- Electrical Contractor
Well, to be more accurate (I hope), the apparent, or relative (to the universe), angle changes, but the actual phase angle of the voltage between any two points doesn't change in any way. That would be like saying that a positive DC voltage is now a negative voltage, because you decided to swap the test leads of your voltmeter.rattus said:. . . the phase angle of a sinusoid can be shifted 180 degrees by changing the reference of the voltage measurement or sense of the current measurement.
Using a bi-polar supply is a better comparison, anyway. Of course, with a split power supply, if you connect one lead of your voltmeter to the circuit common, one pole of the supply will appear positive and the other negative, but the two halves of the supply are clearly "in phase", in the sense that the voltages add, like two batteries in series.
Here's a little (elementary) ditty I posted a while back: http://forums.mikeholt.com/showpost.php?p=708650&postcount=4
