I understand for a front and rear access swithboard, you would follow the NEC Article 110 to come up with the proper working clearances for the front and back.
But, for a front access only switchboard I was thinking you can have it up closer to a wall but would leave the manufacturer recommended clearance in the back. Is this usually the case or is there a larger amount of space usually required to be kept in the back for front access only equipment?
Would this also be true for transformers, meaning I can have a transformer's rear up against a wall but would leave the manufacturer's recommended clearance in the back?
Thanks
Thanks
