LarryFine
- Henrico County, VA
- Electrical Contractor
You made money doing what the customer wanted and/or needed. Is that a bad thing?
And makes up for that during cooling season.
How long is your estimated return on investment?
Remember that heat lost from a tank style heater during heating season is not lost entirely, it puts that much less load on your heating system.
If you live in a northern state you probably have a longer heating season than cooling season. This will have some effect of the true ROI of installing the instant water heater gas or electric.
I have a geothermal heat pump in my home and it also has de-superheat circuit for hot water heating. I don't have numbers to back it up but I'm willing to bet my hot water cost less than the instant water heaters during cooling season, for the same amount of water used during same time periods.
...the last place I had changing to a gas fired tank less, from a 40 gal tank dropped almost $150 off my gas bill a month, but it was only me living there so it didn't fire all that much
Sounds like an inefficient water heater in the first place - probably losing more heat out the exhaust than you are losing from the tank while sitting idle. If it has a standing pilot that alone may cost you $10 per month in gas.
