installing a ground rod
cadpoint
Durham, NC
Your floor apron could be up to 2' thick there and as wide there
..............\_____.|
The height of the wall determines the apron's size and depth around the edges.
LarryFine
Henrico County, VA
Electrical Contractor
I drilled about 1 1/2 feet from the outer wall and about 1 1/2 deep.
Have you tried a drilling in an out-of-the-way area inside the building? Nobody says the rod has to be outside. Or, horizontally through a basement (if there is one) wall?
