It may not be "illegal" in the sense of it being criminal.
It is generally proscribed by NFPA70E and OSHA has been leaning toward making that the default electrical safety standard unless an employer comes up with something else on their own.
However, because it is generally proscribed does not mean that OSHA and NFPA70E don't allow for some limited exceptions.
No, just breathing is probably a criminal activity somewhere, if anything we as living beings do emit greenhouse gases. Dying is probably illegal also, after all we will emit more greenhouse gases as we decay.Want to bet?
Want to bet?
Unless maybe it is a coworker that gets injured instead of just the guy doing the work.There are potentially some criminal penalties if you allow hot work and someone dies.
For the person engaging in the hot work the chances of a criminal penalty approaches nil.
"NO TRESPASSING.
Survivors will be prosecuted."
I just got done with OSHA training. Hot work it not illegal in the least. You have to full out hot work permits and be able to justify the need. Also the only requirement to be able to work on energized circuits is to have a few hour OSHA class, after that in their eyes you are a "qualified person"
I don't agree with them that the class will qualify you to do energized work, however after you complete OSHA 30, that qualifies you. I don't agree with it, that is just what I was taught. You are correct in that there has to be more of a danger involved with a shut down than to perform work live. There are very few cases where a shut down is not feasible.Not really that simple. 2015 NFPA 70E, which OSHA can, has and will continue to use as an idustry standard defines an electrically qualified person as, "One who has demonstrated skills and knowledge related to the construction and operation of electrical equipment and installations and has received safety training to identify and avoid the hazards involved." No one is going to come in off the street, spend a few hours in a class and come out a steely eyed electrically qualified person. Safety training isn't all there is to it.
In terms of justification for energized work the justification can't just be convenience or expedience or it costs too much to shut down. A valid justification might be life support or life safety systems (think hospital) or an ongoing industrial process where shutting down the process could create a greater hazard than allowing energized work. Troubleshooting and testing however are exempt and also don't require an energized work permit.
On the other hand a master electrician with 20 years experience who has never had the two hour class on OSHA is not yet qualified.
And an employer who throws him in cold to do electrical work is in violation.
However my understanding on OSHA is they don't make any such rules or say you must use 70E. An employer must have an electrical safety standard but is up the the employer to establish such standard. The use of 70E is just one of the most popular ways to do so. One could write their own standard if they wanted to, but should things come to litigation, it is much easier to depend on a third party that has put extensive research and time into writing the standard, as well as consideration that they do continue to put in research and keep updating such standards.
If you go with your own standard and someone is injured or killed and they sue you, how are you going to put up defense that your policy was indeed "safe", unless you put the kind of time and money in writing the policy as NFPA has put into 70E?
OSHA does not apply to a single man shop where no other tradesman are present on private works... The minute another trade arrives on the job and can be affected it is a differnent story.
