BCK said:
Many people have these in there homes. Maybe I'm wrong, but isn't it against code to directly bond a neutral to ground in a residence other than at the Service Entry Panel?
Yes, but you are confusing the issue. You are not bonding the neutral comming from the service panel with the transformer input. You are creating a completely new seperately derived system on the secondary side, and a new ground reference point.
After reading this I think I should be in the market for something else.
Yes I believe so from what I can gather. You are looking for one of the four methods I posted before this one, like a new scope with built in isolation.
Most scopes have the common input referenced to the chassis of the scope, which makes it impossible to take bridged or balanced measurements without using something like a differential input mode, a add-on isolation amplifier, or dangerous modifications like cutting the groud pin off.
