jxofaltrds
Inspector Mike®
- Mike P. Columbus Ohio
- ESI, PI, RBO
Well if island receptacles are dangerous so is every outlet in the house with lamps, tv's, etc that are plugged in.
Yes. Maybe we could learn from the Amish.
maybe but to a lesser degree, the kids crawling or barely walking are not strong enough to pull off a tv . You know hot grease is much worse than a lamp or radio .
I usually would try and install a piece of plug mold at the top of cabinet, under the small counter overhang, either in stainless or a color matching cabinetry so it blends in. Now that tamper resistant is required, I am not sure if any tamper resistant plug mold is available.
The panel has debated the issue of where to mount receptacles on islands over numerous code cycles. The current wording of the NEC provides a reasonable set of rules to address practical mounting based on the construction of the countertop and cabinets. Deleting the section entirely would leave substantial areas of modern kitchens without any receptacles.
JMO, kids, pets, clummsy people, and idiots should not be around cooking spaces when they are in use, this is covered in the common sense chapter and should also be in the criminal offense chapter for those that would allow them to be.
Roger
just like Guns and Cigarettes. If you smoke in bed and set the bed on fire who is to blame, the mattress co. the cigarette co. or the dummy smoking in bed.
If you leave a loaded gun around a child and he shoots someone or himself, who is to blame, the gun co. the bullet co. or the dummy that left a loaded gun laying around?
I side with the law that blames the gun owner and say the same logic applies to fry pans, hot plates, etc. and kids.
Darwin's theory is cruel but accurate, "You Can't Fix Stupid!"
Why doesnt every one wire all the c top recepts below the ctop if it is nothing to worry about ?
And when you come to terms with that you can move on to other issues.There are plenty of idiots that will move in and out
You miss the point , I am not worried about who gets the blame , if its wired to code I doubt it would be the electrician, I wont be the idiot, just because the NEC says I can be it . Why doesnt every one wire all the c top recepts below the ctop if it is nothing to worry about ?
Because no one wants them there and it would not be code unless it is an island or peninsula. No one chooses under the counter for placement but with islands and peninsulas there isn't much choice.
We do have alternatives dennis , every one go here , you might learn something today http://www.codecheck.com/cc/schwan.htm :grin::grin:
I believe I mentioned the tombstone a few posts up. I called them pop ups.
