Our local USGBC chapter is having a LEED for schools meeting in which a local LED manufacturer will be talking about the savings Schools can gain by using LEDs as a replacement for fluorescent. I am concerned that this LED manufacturer is significantly overstating the performance of his product and playing off of the public?s excitement of LEDs to make a quick profit. Schools need every penny they can right now so I hate seeing them wasting it on snake oil.
I read the description about the meeting on the group's website and a big red flag popped up for me when it describes LED?s as using 95% of its energy for light and only 5% for heat. There is no way this is physically possible. The actual value for LED light energy is a range from 1.5-15%. Manufacturer quality is very dependant on this. Look at this luminous efficacy table on Wikipedia.
http://en.wikipedia.org/wiki/Luminous_efficiency
So I looked into the manufacturer?s website which is very sparse on real data. The first thing I saw was the extremely high lumens/watt performance. Some higher then the best laboratory tested LED?s.
5775 lum / 38W = 152 lum/W
2925 lum / 15W = 195 lum/W
1900 lum / 8W = 237 lum/W
4425 lum / 18W = 245 lum/W
http://www.cleanlightgreenlight.com/CLGLMediaKit.pdf
My job is building lighting design and it still took me a couple of hours to sort thru how they?re fudging the numbers and I still don?t see everything that they?re doing. What hope does a general consumer have?
They?re using ?effective lumens? instead of lumens in their data. Without any description of what effective lumens means or why it?s more appropriate then lumens. The lumen is actually an SI unit which has been used for about 100 years for all sources of light. Looking on another LED website and it appears they?re adding 46% to lumens to create effective lumens. Just because of the color of the light, I think. This would mean the 245 lum/W value above is only 168 lum/W if we are using SI units. My best guess as to what the difference between a lumen and effective lumen is would be the difference between photopic and scotopic vision. This is the difference in perception for the human eye in daytime vs nighttime conditions. Unless the LEDs are being used in small quantities at night there?s no reason to use scotopic, or effective lumen values. Unless to inflate their numbers.
http://www.ideallights.co.uk/corporate/downloads/commercialgradeledT8.pdf (2MB file)
Still 168 lum/W is really, really high performance. And this is where I?m stuck with lack of data. There could be heat losses, driver losses, design losses. I even question where and how the lumens were measured. Has this ever been tested in an independent light lab? An article in LED magazine gives us some idea of what?s going on. Neal Hunter, CEO of LED Lighting Fixtures warns that ?there?s a gap between data and reality?.
http://www.ledsmagazine.com/features/4/4/9
Even their labor savings claim isn?t true. T8 lamps last 20k hours. LED?s last 40k-100k hours. Best case a T8 lamp would have to be replaced 5 times before the LED lamp reached its end of life. These T8 lamp replacements fit into a regular T8 fluorescent lamp socket but the electronic ballast has to be disconnected from the circuit for the LED replacement to work. I?m sure opening the fixture and disconnecting the ballast will take more time then replacing a burned out T8 lamp 5 times.
I also question if these are such wonderful products why do the manufacturers sell directly to customers rather then to lighting designers like myself who have to scratch for each watt of savings on LEED projects. Lighting is a simple yet confusing subject. And not a whole lot of regulation which allows companies to say just about anything, especially for new products. Do they even have IES files so accurate computer lighting models can be make to know how many fixtures are needed in each room?
LED?s are exciting and new. Great for accent lighting, task lighting, cold environments. But I don't feel they?re ready for general building lighting to replace fluorescent. I fear that this presentation will just be a big sales pitch about how perfect LED lighting is. No light source is perfect. Everything has pros and cons. With the advancement of LED lighting maybe in 5-10 years it will be closer to the perfection currently marketed. And maybe better marketing rules so the public knows what they?re buying. There?s even a new Energy Star rating for LED lighting now.
I?m tempted to attend this meeting but I may not have time. Also I can?t say I?m looking forward to being the naysayer in the corner of the room. People like the thought of LED lighting more then they like some engineer in a crowd.
Has anyone else seen this type of marketing or have any additional knowledge about how they're inflating their numbers?
