ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Absolutely not.Seriously? You wanna start talking about WIND POWER now?
In CA you get paid a small amount for the excess generation that you didn't consume in that fiscal year.
Other states could treat it differently.
But with net metering it is possible to get a small check back from the POCO for excess power generated.
Usually the payment per kwh is close to the PV LCOE, so you don't want to generate a whole bunch extra.
If you add a battery system, you now have additional costs to build the system but it doesn't reduce your bill with the POCO any.
"Usually the payment per kwh is close to the PV LCOE, so you don't want to generate a whole bunch extra."I honestly don't understand this sentence at all
Ok.
Usually the payment is somewhere around $.04/kwh to $.06/kwh
The LCOE for PV installs is close to that as well (maybe $.05/kwh or maybe $.07/kwh)
SO
If increase the array to larger than needed, and generate an extra 1000kwh, then the owner gets paid $40 each year.
However the owner paid $1400 to buy the capacity to generate those extra 1000kwh.
That means the owner doesn't gets all his money back out of that investment. (but at least gets most of it)
Or at the other end of the pricing, it might be that the extra 1000kwh gives the owner an extra $60 each year.
And if he only paid $900 extra for that additional capacity he gets his money back in 15 years.
So upsizing the array to generate excess isn't going to be a great benefit, nor is it a huge detraction either. Most likely generating too much will slightly push out the PV owner's pay-back time on the investment.
So you want to look at RI - sure why not.I think you'll find my (real) numbers have an effect!
So if you were being realistic instead of argumentative, you might say "BESS works in X states but not Y states".
We'll need a bit more information in order for to do that.
Preferably with links to the information since I was not able to find anything about $.245/kwh on nationalgrid website
* price per kwh when selling to the POCO
* price per kwh when buying from the POCO
* how net metering is calculated in RI. (looks like it's a per-month net metering with actual $ being paid out each month)
* estimate for $/kwh for batteries and related equip. (I think Powerwall has been estimated to be about $.30/kwh - so that's probably the upper end of the range)
* estimate for $/kwh for PV generation (PV LCOE)
* How many kwh are generated
* How many kwh are consumed
Rhode Island price for electric | 21.07 | <----sell and buy, net metered |
The selling to POCO prices changes depending on which program you're in- net metering gives you the WORST rate, which is equal to...
http://www.eia.gov/electricity/monthly/epm_table_grapher.cfm?t=epmt_5_6_a
Rhode Island price for electric 21.07 <----sell and buy, net metered
You get paid 24.5 cents thorough the other *better* program!
Here's a task if you are so interested- tell me the system kWh nameplate size limit with the 24.5 cent rate. (link at end of comment, you'll want to look at the REGP (Growth Program))
If you generate more than you use- YOU GET ZERO MONEY FOR IT.
If you want to use $.10/kwh, we can assume it's something other than a powerwall and is therefore cheaper, so that's fine.30 cents for a Powerwall is way off- it's 10 - 15 cents.
Ok - so PV LCOE = $.10/kwhMake it higher here than yours in Cali just for fun, call it 10 cents
Please pick some numbers so we can do the analysis.* How many kwh are generated
If you want, feel free to pick numbers for 2 or 3 scenarios.
OK - so do you want to use $.245/kwh for selling and $.21 for buying power?
Or $.21/kwh for both selling and buying?
So I think it's saying that credits roll over to the next bill until they're used up. I don't see anything about them being limited in how long they stay as credits. Other states they'd basically evaporate at the end of each fiscal year.
So - do these credits roll over from one month to the next forever?
What is the (non-refundable) credited $/kwh? ($.21/kwh?)
Oh - I forgot - for the batteries option we also need to know how many of the kwh consumed go through the batteries first. (ie. how much of the kwh are consumed at night)
So what is it, exactly, that you are trying to accomplish here? To convince me that batteries are always cheaper/more profitable than grid storage? To convince me to run out and buy everything I need to have a battery system in my house? Forget it. It ain't gonna happen. Your "math" is all sleight of hand and conjecture.10kWh per 24 hours. 5 a day 5 a night.
Then 4 a day and 6 a night.
Then 6 a day and 4 a night.
Good luck- you can try all the numbers you want- net metering loses. I've already done the numbers. But have fun! :happyyes:
Ok - so 10kwh/day - we'll do a month since that's the billing cycle.
Scenario A - no PV
$.21/kwh * 300kwh = $63.
Scenario B - net metering, producing and consuming 300kwh/month
$.10/kwh * 300kwh = $30
Scenario C - sell the power at a higher rate (.245/kwh) and then buy the power you consume from POCO.
$.10/kwh * 300kwh - $.245*300kwh = -$43.50 [generating and selling the power]
$.21/kwh * 300kwh = $63 [buying the power you need]
Total: $19.50
Scenario D.1 - use batteries (4 kwh at night)
$.10/kwh * 4 * 30 = $12 [cost for storage for the 30 nights]
Total: $42
Scenario D.2 - use batteries (5 kwh at night)
$.10/kwh * 5 * 30 = $15
Total: $45
Scenario D.3 - use batteries (6 kwh at night)
$.10/kwh * 6 * 30 = $18
Total: $48
Net metering isn't the winner here, since you have a program where you can sell the power for even more than you can buy it.
But buying batteries is obviously not better than just using net metering.
I gave batteries advantages even - I put the price per kwh at a low $.10/kwh. I also made it more favorable for batteries because I didn't add in the extra kwh that would need to be generated because they would be lost due to battery efficiency losses.
But if you are yourself convinced, put your money where your mouth is. Go out and buy a battery system and report back here how it is working out for you. Show me real numbers. I'll hang up and listen.
Well if the POCO lets you do it, I'd sell all of it from one meter, and buy all the power on a separate meter- that would give the best financial solution.C- Almost? I get $20.25
Your way seems weird, because you didn't sell or buy ALL 300kWh. *Nor* did you buy all 300kWh!
Well, that all 300kwh were generated by PV, so 300 * .10 would be correct.D 1 2 and 3 - No. You did it again- you put the 10 cents with all 300kWh, and "undercharged" for night time by dropping it!
And of course dropped the fact that you covered 100% of the bill, thereby *saving* $$!
Really!
I agree that the answer for D-1 is $42.D 1- 4kWh a night with BESS
You used 180kWh during the day @ 10 cents = $18. You put 120kWh into BESS @ 20 cents = $24 (see how PV+BESS < POCO price there? Please?)
24+18= $42. You paid $42 for that month. You did NOT pay 63! You AVOIDED that cost- that is the whole reason for PV, BESS or not!
So if you paid $21, then $21 must be the cost. So you saved $42!63-41 = You saved $21. Cost (42) minus savings (21) = you PAID 21! BESS wins!!
$48 is more than $30 from Scenario B. Batteries lose compared to net metering.D 4 - 6kWH a night BESS LCOE = 10 cents
120kWh day = $12.
180kWH night (@ 20 cents) = $36
36 + 12 = 48.
Sound familiar? BESS by (the same) nose again!!
I don't know.Are we...understanding each other now??
You can't just guess-timate, will you at least give me that?
If it's for a residential location, you're better off putting that money into something else.You of course can't get real numbers until it's up and running so, sure. I'll do that.
Unlikely IMO. I see batteries as a much more mature technology than most of the things that goes into cellphones.Like I said about smartphones...in 5 years BESS will probably be 5 cent/kWh.
But if the POCO doesn't allow that, then they don't allow that, and we'd have your result ($20.25)
I don't know.
Do you understand yet that battery systems simply aren't a good solution in most places in the US?
We've been through 3 states so far, and the answer has been the same: Battery systems aren't financially useful for residential customers because of net metering.
Since you have young kid(s), I'd strongly suggest using it for funding a 529.
ggunn may be happy to let you waste your money - but I think of your kid, who probably can use that money in 14 years to pay tuition.
But we'll see.
