Loaded test question!!!
david luchini
Connecticut
Engineer
So I'm supposed to comment on your posts while you ignore the better part of mine... :roll:
So I'll take that as a No, P = H * D wouldn't give the pressure at the base of the cylinder in my example.:grin:
Close enough? Well taken that the all time percentage of objects weighed in places much, much closer to Earth's mean radius versus atop Mt. Everest, I'd guess the ratio to be astronomical.
So if the result would be close enough "most of the time" you'd just ignore the other times? I wouldn't
So do you also account for g-force deviation due to lattitude and the angle of g-force?
Yes, of course. Acceleration is a vector. It has not only magnitude but direction.
In a weighing of product, do you continually compensate for air bouyancy?
I don't have much call for weighing of product (I've never tried to weigh an electron;)) but I'd think you don't need to compensate for air buoyancy. If the air is more buoyant, the object would weigh less. If the air is less buoyant, then same object would weigh more. More evidence that acceleration must be included into the equation for pressure.
You do know the federal trade definition of a pound weight is within a vacuum, right?
I had no idea, and couldn't find any such definition on FTC.gov. Maybe its true, but it just goes to show if the FTC is that precise about the weight of a pound, then "close enough" probably isn't good enough for them.
When is the last time you checked the gravitational force at your location?
Never have. How about you?:)
Smart $
Esteemed Member
Ohio
I never have either... and this is the summation of my point, and the ultimate pitfall to the premise of your argument. You emphasize local adjustment as a necessity, but yet you do not practice what you preach. ;)
If this was such a major concern, don't you think there would be online information about practically every populated location throughout the world? I looked and didn't find anything more than for a few major cities. Perhaps you can do better.
david luchini
Connecticut
Engineer
I don't emphasize any "local adjustment" as a necessity, I emphasize ACCELERATION as a necessity.
Force = Mass x ACCELERATION
Pressure = Mass x ACCELERATION/area
Would the pressure at the base of the cylinder still be calculated by P = H * D? Of course not. You'd be off approx. 18%. Add "acceleration" back into the equation: P = H * D * a, and you'd have a complete equation.
The ultimate pitfall of your argument is that by ignoring ACCELERATION so that you can leap to Force ≈ Mass, you'd provide a solution that is not nearly "close enough" but is way off, in the example above.:)
Smart $
Esteemed Member
Ohio
Come now, do you really think I would apply lb(Force ≈ Mass) where it does not apply??? :roll:
Besoeker
UK
Taken out of context, it sure seems that way ;)
Within the context of my comment and the discussion on my part, places on earth where gravitational force is at its extreme, on the moon, or in space are most certainly are excluded from the other side of a leapt chasm. :D
What force will give a mass of 1lb an acceleration of 1 ft/s^2?
gadfly56
New Jersey
Professional Engineer, Fire & Life Safety
That would be 1/32.174 lbf. In the FPS system, the unit of mass is the slug. So one pound force provides an acceleration to one slug of one foot per second per second. If that slug is sitting on the face of the earth where the local acceleration field is 32.174 ft/sec^2, a scale calibrated for lbf will read a "weight" of 32.174. So if you use a spring scale and dangle an object from it and it "weighs" one pound, it's mass is about 0.0311 slugs, or coincidently, one poundal.
gadfly56
New Jersey
Isn't it about 0.031 lbf?
Didn't I say that in #92 :-??
There is obviously a real problem with terminology here, especially using "pound" to indicate mass and weight. A object that "weighs" 100 pounds exerts a force, as measured by a scale located in an acceleration field of 32.174f t/sec^2, of 100 pounds. It does NOT have a MASS of 100 pounds because "pound" is not a unit of mass in the FPS system of measurements, nor any other. Technically I do not "weigh" 200 pounds (again, I wish :grin:), I exert a force on the earth of 200 pounds in a gravitational field of 32.174 ft/sec^2.
Smart $
Esteemed Member
Ohio
To obtain that result you have to take account of the gravitational constant.
Of course! ...the force acting upon the mass is something other than [Earth's] gravity. With pound-force defined by Earth's gravitational force, its magnitude has to be part of any conversion to a force of different magnitude. I believe I already mentioned in the context of my earlier posts, lb(force ≈ mass) is only appropriate when [Earth's] gravity is the only force acting upon the mass.
