IAMAMT
- Ogden, Utah
I have a machine build production line that has required 2/0 Equipment Grounding Conductor at 1000 amps as per NFPA 79. It has 10 arc welders on the machine. It currently has a 2/0 Welding Cable 20' long and must be able to move with the vibration of the machine. The OSHA Inspector will not allow the welding cable because of the potential of insulation damage and physical contact by employees. Any suggestions on what to use.
