goldstar
- New Jersey
- Electrical Contractor
You guys (and girls) are way over my head with the terminology but I'll take your advice and buy ready made patch cables. I have to drill a hole in a hard wood floor to get the CAT-5 wires to the modem and I'd like to make the smallest hole possible. That's why I was asking about making up male ends. I also did not know the wiring had to be stranded. Thanks for that. From what I've read, these patch cords will be strictly for ethernet connections.
Thank you Fulthrotl for your extensive explanation on what bitcoins are and what bitmining is. I still don't know what they are and why there's a need for 3 or 6 bit-mining units running 24-7-365 in one house at about 11 amps each.
Anyway, my concern is getting ample power to each of these units and running the ethernet cables. Beyond that I don't really care if they're used to mine bitcoins or track satellites. It's hard to believe that these little 12 lb. units take 11 amps to remanufacture 11.6-13 volts. But, they have two fans so I'm guessing they run really hot.
