When a voltage waveform is chopped by an SCR how is the quanity of the measured voltage determined when measured?
Lets say the SCR is only conducting for 50% of the top half of the waveform, then how would this voltage appear when measuring. Because you are measuing half the positive half, it will still reach peak magnitude, but it will only be half this top portion of the waveform. So would the RMS voltage measurment still remain the same? If you were looking at it with a meter would you still see nominal voltage?
Again just looking at the top half of the waveform, what if the SCR was conduting for the 1st 1/4 of the top half, then went off, and didn't start conducting again until the last 1/4 of the top half. How would this voltage value be measured?
