MV is superior in many ways,
But it is liable to corona damages.
Only when done by untrained people. Seriously, the only one one who should be making up MV splices and joints are licensed people trained in handling MV.
Those MV panels with polymer insulators developed corona discharges and were damaged, when heater stopped working.
I once put in a 600HP 4160V soft starter for a local water utility and after doing the startup and training, the maintenance supervisor wrapped up by asking their electricians if they all understood. They said yes, but their lead electrician added; "It doesn't matter though, none of us are qualified to work on MV anyway." Longer story short, the district had to pay to send them all to additional training, after which they then all hit the utility up for raises. A year later they needed another 600HP soft starter, it was designed for 480V...
So pretty much if the equipment fails and maintenance is not done then trouble will follow. Got it.Those MV panels with polymer insulators developed corona discharges and were damaged, when heater stopped working.
Space for the energy and heat to go other than all in my direction and anything to deflect what can come in my direction is what I look for in either case.I'd rather be close to a MV distribution fault in open air than inside a switchgear with a 277/480V fault. Just me, though.
LV panels are different than MV panels so I would not expect them to behave the same way.A LV panel would not fail that way if under the same circumstances.
Iam not talking about the constructional differences between LV and MV panels. It is about nature of LV and MV voltages: corona damages in MV and not in LV, for example.
May be because of that, code included up to 1000V in LV category?
They are constructed different because their natures are different.Iam not talking about the constructional differences between LV and MV panels. It is about nature of LV and MV voltages: corona damages in MV and not in LV, for example.
Yes- but one can have other problems in LV not seen in MV.
