kwired
Electron manager
- NE Nebraska
A volt meter to verify the color represents what you think it shouldWhat would you propose instead?
As far as I'm concerned the NEC could make a rule that every conductor has to be black.What would you propose instead?
Are you saying that there is actually no real life safety issue with termination taping wires of all sizes?
Darn tooting I am. Why is a phase taped #4 neutral safe, but a #6 is not. Hint: no reason.
As long as conductors are properly identified, color tape or other effective means, I could care less about what size conductor is involved.
Exactly. The only reason I could think of why smaller conductors would be a real life safety concern without a continuous factory finish for identification, is that statistically there are going to be a lot more of them, and a lot greater chance that you would mix them up. But provided that you don't mix them up, there shouldn't really be any safety concern.
One possibility is that at the time the rule was made availability of colored wire in larger sizes was lower.
Also stocking multiple spools of wire in different colors is more of a burden for larger sizes than for smaller ones. The location of the dividing line is, of course, arbitrary.
Since there isn't really a good explanation for not being able to phase tape a smaller conductor, I came up with my own.
My thoughts are, the smaller the conductor your trying to tape, the crappier it looks.
Maybe that's why.
JAP>
Well......I am gonna say Goldy's point is just a tad more plausible.
But, ya never know...
Hey,,,,, your a moderator,,,,, your not supposed to take sides,,, your supposed to stay neutral,,,,,, and if your a size 6 or smaller you should have an overall outer covering of white or gray I might add. :lol:
JAP>
JAP>
You can easily get white and green because NEC requires us to use them. If they upped the size to say #1 we would have this same conversation but with #1 being the dividing line of what is commonly available in white/green.Well the easy answer is that after #6 wire usually only comes in black, so up to #6 there is no need to
re-identify it as you can get white and green.
See, you're catching on. I don't know why everyone says all those awful things about you. :lol:It's like the joke if the Queen had.........You can easily get white and green because NEC requires us to use them. If they upped the size to say #1 we would have this same conversation but with #1 being the dividing line of what is commonly available in white/green.
