jwatts
- Chicago, IL
Recently completed a couple of three unit apartment buildings. We fed the outside GFI off of the living room circuit, which is on an Arc Fault Breaker as required. Today the inspector knocked the use of a GFI receptacle on an Arc Fault Circuit. Stating the NEC says one or the other. I thought they could be used together, as they are designed for different types of protection. Need something to refute the inspectors decision..... otherwise have to go back and repull the units to put the ouside GFI on a non arc fault circuit.
