- Wisconsin
- PE (Retired) - Power Systems
Voltage drop on a circuit does not require removing the panel cover. Lost neutral can be tested at the meter.
Yes it is 'easier' to test in the panel, and that is what I would do, but what gives us the 'right' to test in the panel?
You asked for any tests would require energized circuits in a residence. Now you want to be specific to a single location.
If you do not use open the panel for your clamp-on meter, then you would need to do it someplace on the branch circuit, say a receptacle serving a kitchen counter top, but doesn't the cabinet infringe on the working space? In previous discussions, the lack of working clearance at locations, like counter outlets, was defended by saying the energized measurements could be made at the panel. Looks like a Catch-22.:huh:
Also, many utilities do not want you 'working' in their meter sockets.
