Cavie
- SW Florida
Can a photo cell be mounted inside a weatherproof panel for house lighting? I've been asking for a bell box under the panel stating that the panel is not listed for the application. Am I wrong??
Okay, how about poking it through a KO?triphase said:why would one install a photo cell "inside" a panel?
You'd have trouble claiming that's not a listed use.georgestolz said:Can we install SWD breakers in a panel? They are switches too.
tufts46argled said:To me it's just like the one's that say you can't make a wire connection inside a panel, a panel is not a raceway! It is a junction box, so why not treat it as such. If I'm wrong please tell me becuase I havn't found in the code I'm wrong.
Dont think that would fly.You would now have unfused in same raceway as fuseddduffee260 said:We do this sometimes also. If you really want to make friends with the POCO then put a photocell on the side of their sealed meter socket. That way when you have to work on the photocell you can cut the sealed tag.
Agreed, 230.7 would preclude an offset nipple being used for both.Jim W in Tampa said:Dont think that would fly.You would now have unfused in same raceway as fuseddduffee260 said:We do this sometimes also. If you really want to make friends with the POCO then put a photocell on the side of their sealed meter socket. That way when you have to work on the photocell you can cut the sealed tag.
I feel my leg being pulled on two counts.dduffee260 said:But Jim, the meter would too be fused. We just had a lightning storm here tonight and I helped the Xcel Energy man change one out on the pole. I was a 2 amp fuse on a 15kva pot on a 12470/7200 line but still was a fuse. Can't we get creative in the fusing department?
