mark the sparky
I posted this question a year ago and you guys didn't get it right...becuase the customer just called and said it is still tripping the breaker.
I have a Pottery Kiln in a shop. Manufacturer specs say to wire it for a 60 amp 240 volt circuit on #6 THHN. I did this and it is tripping the breaker when the kiln kicks to high and thereby doesn't finish the cycle making a bunch of little artists unhappy. Some interesting this to consider.
1. New 400 amp service, 120/208 , 3 phase. (I know it is 208 not 240...there are three other same kilns running on it and they work fine.)
2. Only 6 feet from the panel.
3. Kiln just re-wired with new heating elements.
4. Kiln had a 240 buck boost on it before and still kicked the breaker (which was a 50 at the time).
Fire away guys...give me your thoughts.
