mivey
It is kvarh, kWh, and kVA. I prefer to think of kW as speed. kWh is the energy, kW is how fast you pull the energy off of the system.weressl said:Tell him that he is full of..............................ignorance. :grin:
If you want to keep your job, then you can ask him if he knows what the power company meters are called. If he does not know then explain it to him that they are called (kilo)watt-hour meters and not (kilo)volt-ampere-hour meters.
kVAhr=SQRT(3)*V*I*Hr
kWHar=SQRT(3)*V*I*pf*hr
p.f.(power factor) - as you probably know - representative of the difference between the voltage and the current that occurs when the load is not purely resistive. In the case of inductive circuits the current will 'lag' behind the voltage, so the sine wave does not peak simultaneously. since the V and I component produces the 'work' together the power factor, that is always less than 1.00, will 'adjust' the calculation to arrive at the actual work produced.
kW represents the actual 'work' that the energy provides for the user. The difference can be thought of that the water company charges you for the cubic yards you are using regardless at what pressure it is delivered. (I know the analogy is less than perfect, but hey, offer yours.)
Since the current component determines the size of the wire, or transformer, some POCO's charge for either kVA Demand or power factor a flat monthly fee to recoup the cots of the extra equipment, wiring they need to install to support the 'current' component. Since power factor capacitors 'lower' the current they are used sometimes to avoid the charges or even in plant to reduce the size of wires need to be installed.
The faster you pull energy, the bigger the equipment you must have (like a bigger hose and pump to get the water faster). Bigger kW = bigger kVA
