- Wisconsin
- PE (Retired) - Power Systems
How did you know that was a NEMA 3R just by looking?
The weather tight hub entrance on the top is very noticeable.
The round hole in the center where the meter goes is a clue.
Why? Don't you have meters mounted indoors?:?I could not see it..but it being a meter should have been a dead give away
Sometimes yes, they are still only available in 3R cabinets. Now you possibly could find something not 3R in a multimeter assembly, but in general those are 3R also.Why? Don't you have meters mounted indoors?:?
There are a few ways to do it. If it must go in before the walls are framed then it would need to be mounted on some type of strut or framework. If the walls are already framed it can be mounted right to the studs. The 16" OC studs are the carpenter's problem we just move them to suit the enclosure.
