It is not really the issue of the plug pulling out of the receptacle ... it is more of an issue of the contact pressure between the plug and the receptacle. The tension test is indirectly measuring the contact pressure. That would be much harder to do if you used twist lock devices.So why don't they just standardize on twistlocks?
don_resqcapt19 said:The tension test is indirectly measuring the contact pressure.
