mcclary's electrical
- VA
So you'll bid a house based on nothing more than square footage? Dat's just plain nuts.
No, you're plain nuts to say that without asking me how much!
If you've got a normal GC, building normal houses, there's no reason you can't attach a number that will work for his style of home. Assume a worst case number,,,and if it's an easy home, you'll make even more money, if it goes as expected, then your number stands true. How can something be nuts without knowing the number? Could somebody "magically" make you put in 30 extra circuits?or make your homeruns circle the house three times before hitting the panel? There's only so much wire that can go into a home, only so many required circuits, only so many recpetacles per sq ft, only one laundry circuit, there's no reason not to make this easy on yourself and start attaching numbers to the similar houses
