Does anyone have a schematic of this type of 480v grounded or ungrounded system ?
it only has 480 line to line no low voltage at all
This schematic is all over the web.
Can you check the voltages with the disconnects open, no load? See the readings for yourself? Sitting here, I can't understand why one said the pot is bad and the other said it is good, unless one checked it under load, and the other checked it without load. Besides, in order to correctly check the pots, they need to be seperated.
