GentlePeople,
The term Symmetrical Components, need not be feared, although on this forum some "partcipants" seem to be. Come on fellas... it?s only a mathematical tool!
Early in the history of Electrical Engineering, fault-currents for "balanced", 3-ph short-circuits were easily determined with classical mathematics: Kirchhoff's laws; D-Y and Y-D impedance equivalency; complex numbers; superimposed currents; and 3-phase circuit "transformation" into single-phase circuits.
As circuit complexity grew, both in size and interconnection, the classical approach became tedious and often unwieldy. In 1918 C.L. Fortescue (he was with the Westinghouse Electric and Mfg. Co.) introduced the "Method of Symmetrical Components!? It is a solution, preferable to those mentioned above, for solving problems having "unbalanced" conditions! Examples are: line-to-line; line-to-ground (earth); double-line-to-ground, open-circuits; unbalanced sources; unbalanced loads; unbalance impedances connecting source and load; etc!
Avoiding deep technical discussion, it is simply a means to "transform" a seemingly unwieldy, complicated system of voltages or currents or impedances, into symmetrical ones. For example, the method changes unequal-voltages, displaced by unequal-angles into a set of 3 sets of equal-voltages:, as follows:
o The 1st set of three equal voltages, referred to as the positive-sequence component, are separated by 120?, having a phase- rotation, say A-B-C!
o The 2nd set of three equal voltages, referred to as the negative-phase component, and whose magnitude is different than those in a) but having a phase-rotation in a direction opposite to a), that is, C-B-A.
o The 3rd set of three equal voltages, referred to as the zero-sequence component, having equal magnitudes, in phase
with one another
This method is used to solve unsymmetrical faults listed above, as well for operating generators, and motors under unbalanced electrical conditions. A key mathematical element for its success was the introduction of an operator, 'a', to rotate vectors 120?. Of course, it is analogous to the complex-number operator, 'j', used to rotate a vector 90?!
Although details can be found in Electrical Engineering (power) text books used by power engineering students, if examples are sought, perhaps others, like, KingPB can oblige!
Regards, Phil Corso
