110323-1336 EDT
sgunsel:
I agree with you.
In the State of Michigan the government has required two major utilities to provide some very good incentives. But these are only going to last a limited time.
As good as the Detroit Edison incentive is I can not economically justify it in my case. You would have to be in the open country with open sky and optimum orientation, or be lucky in the city, and have excess capital and a high income tax bill to get a reasonable payback. This won't include any battery storage capability.
As an aside. The Ford Motor Company at the Wayne Michigan assembly plant for the Focus is installing a large solar array. Someone told me this is in excess of 1,000,000 watts capability. I believe it is associated with some incentive. Also the adjacent plant that was formerly Michigan Truck where the Expedition and Navigator were previously made has been converted to produce the Hybrid Focus. It probably also can build the standard focus and possibly other models. It is now producing cars based of the employee lot and the assembled car lot. I suspect that some of these are the hybrid.
mull982:
First, a part of the inverter is designed to extract maximum power from the photovoltaic array. This is roughly the knee of the photovoltaic V-I curve. This is constantly changing and the inverter adjusts for the array change. Then within a useful, but limited range, the inverter output works like a constant current source.
Consider a 10 V battery with an internal resistance of 1 ohm and a load resistance of 9 ohms. The load current is 1 A and its voltage is 9 V.
From a 100 V battery I connect an 81 ohm resistor to the 9 ohm resistor. If the 10 V battery is disconnected the voltage across the 9 ohm resistor from the current from the 100 V battery is 10 V. Reconnect the 10 V battery and no current flows thru the 1 ohm internal impedance of the battery.
Change the 9 ohm resistor to other values and you can see how the current distributes between the two batteries and how the direction changes to the 10 V battery.
Why do we view the inverter as a constant current source?
Because it is designed that way.
Are both the inverter and grid voltages equal for this case? If not how are they adjusted?
You need to view the primary voltage to the pole transformer as a constant. Combine with this constant voltage source the impedance from the transformer primary point to the house main panel point. The main panel is where the inverter interfaces. All house loads emanate from the house main panel. Thus, three things interface at the main panel --- the grid supply, the solar supply, and the house loads. All these voltages are equal at the main panel at any time, because it is one and the same place. Under load conditions the voltage at the main panel is different than at the sources or the loads.
I'm not sure why you are stating that out of necessity the house voltage equals the grid voltage. If the voltages were equal and the grid had a lower source impedance as you mentioned wouldn't more current want to flow from the grid than it would the inverter?
If there is no energy flow from the grid to the house, then there is no current and the voltage drop thru the pole transformer and distribution wires has to be zero. Therefore, under these conditions the transformer secondary voltage has to equal the voltage at the main panel. Note: no load current on the transformer and there is no voltage drop across the internal impedance of the transformer.
When you mention "House Voltage" is this the same voltage as the "Inverter Voltage" . In other words are you saying that the house voltage is always the same as the inverter voltage?
In this case how does the house voltage become higher than the grid voltage.
I think it will make sense to me after I clarify these 3 cases.
When I refer to house voltage it is the voltage at the house main panel.
