quogueelectric
- new york
I hate stranded wire. If you cant pull solid 12 in that is just sad.
quogueelectric said:I hate stranded wire. If you cant pull solid 12 in that is just sad.
rustyryan34 said:Yeh stranded wire around outlets sucks
jeffhornsby said:stranded has more resistance due to skin effect not much with your smaller wires but that might be why
jrannis said:Stranded wire has way more surface area than solid wire. I believe the theory is that electron flow is conducted on the outside of the wire.
emahler said:bbaumer, that's the point...what's the difference and why are they so adamant about using solid....when using back wired spec devices, the pressure plates actually make a better connection to stranded in my opinion....also, stranded #10 is easier to work with than solid #10....
i'm just not understanding the logic, if there is any....
If people would just strip the correct amount of insulation and insert the conductor all the way they will never pop out on their own.Dennis Alwon said:I love them also. I can't tell you how many service calls I get from you EC's that use the pop ins. You keep me employed. Thanks.:grin:
I truly feel that there is nothing wrong with them if used properly and following the strip guage(stripping enough insulation off) and pushing the wire all the way in = no problems.stickboy1375 said:Your pretty brave admitting that :grin:
you said it brother and I couldn't agree moreelectricmanscott said:The reality is there are probably a gazillion backwired devices out there and while there certainly are failures I (and the UL obviously agrees) don't think it is really an issue.
Maybe and maybe not. Heat does weaken the springiness of metal, which allows more heat, which weakens the metal more, etc.steelersman said:I truly feel that there is nothing wrong with them if used properly and following the strip guage(stripping enough insulation off) and pushing the wire all the way in = no problems.
Welcome to the corral, pardner!APavlatos said:Howdy fellas, I am a new guy here just looking around.
Thank you!LarryFine said:Welcome to the corral, pardner!
steelersman said:Hey I love those stab in outlets and switches for residential. You can only use them for 14 guage not 12 but they are awesome IMHO. I've never had a problem with them. I've never had one pop out on me. They're great. I know commercial guys tend to think they are crap but they are huge timesavers.
