Fallriverbryan
- Fall River, Wi USA
An encoder doesn’t “do” anything, it just provides you with pulses as it revolves, ie 3600 PPR (pulses per revolution). You need something that tracks the rotation using these counts. Then you either need to “home” your counting every time you cycle power, or use what’s called an “absolute encoder” that knows where it was after powering back on. SOME very advanced drives are capable of being the intelligent device that does the tracking of the encoder pulses, those are not going to be the inexpensive ones.
Do you have an example of an absolute encoder with an analog output that you have used in the past? Don't need a high resolution but would need to be robust.
Sent from my SM-G950U using Tapatalk
