I know that industry standard for a disconnect or any other switch for that matter is line conductors on top, load on the bottom. Is this a code requirement?:-? The only thing I could find is that when mounted vertically top position has to be on, bottom position of the switch has to be bottom. Case at hand involves molded case switch with line coming in at the bottom, load exiting on top, ON is when the switch handle is in the UP position.
Thank you.
Thank you.
