mkgrady
- Massachusetts
I'm stumped. I am running Romex to a pvc weatherproof junction box.....the kind you would install outdoors with a gasket but I'm installing it indoors. The box is a junction point between a generator and an ats. I'll be terminating 2 14-3 Romex, one #3SER and one 1-1/2" pvc. Drilling the holes exactly where I need them is easy and the reason I like Pvc. The ser connector is no problem and the ser connector is just long enough but the Romex connecter is too short.
The walls of the box are thick....maybe about 3/8"....just thick enough so that a standard Romex connectors throat is not long enough to get a locknut installed. The button type connectors that snap in place don't work either because the material is too thick. I could use a sheet metal box but is just harder to work with. Any ideas?
