Richardtheelectrician
- Kerrville, Tx, Kerr county
Oh, sir. You make me smile. Please Lord stop me now from thrashing this boy.
1. 32 is too young to call yourself a master. It's more than passing a test.
2. Never be happy someone quit or lost a job. Try to be an adult about it.
3. You're not always right (though I know the feeling)
4. Throw away your bender.
I say "throw away your bender" Mr. Crmeschke because a little planning alleviates most bends except needed 90's. Also the correct strap will alleviate the need for ugly box offsets. You're a good sport.
god, i love a troll......
correct strap? is that meaning that one hole straps are
incorrect?
so, you are telling me that in an exposed installation,
box offsets are a waste of time?
the only time i see would be wasted would be redoing
the stuff you put in exposed without box offsets, after
i got the field check filled out.
He is probably talking about these:
http://www.edwardssupply.com/product.php?productid=472016&cat=2368&page=1
I don't like them unless you are running ridgid or using compression fittings.
They still pull the emt back and put a bow in the pipe if used between 2 boxes or instead of a box offset they bow the emt also. We use them because the owner said we were going to..........
Well, first I got called a handyman, and now I get called a troll. Congratulations. I won't miss you people.
