e57
- San Francisco, CA
What about commercial???
ike5547 said:The specific heater in question was a 240 volt, 2000 watt, wall insert heater with a small fan motor.
cowboyjwc said:Package C: This package allows electric resistance space heat, but increases stringency for most envelope features to make up the additional TDV energy that would be used by the electric heating system.
But you can only use this if you have an all electric house.
152(b) 1 c of the California Energy Code. New electric resistance heating systems are prohibited in alterations unless the system being replaced is an electric resistance heating system. If the existing system is gas, propane or LPG, then new electric resistance systems are not permitted.
If you want to PM me I can give you the number for the Energy Commission hotline.
ike5547 said:I had an inspection today and the inspector informed me that it is illegal to install electrical resistance space heaters in California. The specific heater in question was a 240 volt, 2000 watt, wall insert heater with a small fan motor. The job was a residential service upgrade, a new bathroom exhaust fan and the heater.
Can anyone from California verify that this is true? I haven't been able to locate this prohibition within title 24 or anywhere else.
The inspector actually green tagged the entire job regardless of the heater issue.
gndrod said:So the new CA Title 24 has just put the Bathroom resistance ceiling heaters on the CA Consumer Affairs black list or is that just local? There is another compliant answer by using IR ceiling lamps to heat the bathroom (on a timer of course). As far as adherring to energy code constraints, prescriptive or calculated requirements have compensations for structure envelope design energy efficiencies. Heatpumps with backup resistance heating is still allowed on new construction, only thing is that the HSPF/COP factors are raised for Zone compliances. Unfortunately, that can be a very expensive AHJ call. rbj
ike5547 said:What if there is no existing system to replace in a particular room (e.g. the bathroom) but there may be an existing gas system in another part of the house. Would you be precluded from installing a small electric resistance heater in your bathroom?
cowboyjwc said:I would say that if you have gas in the house, the yes it would preclude installing a heater in the bathroom.
